Heating & Cooling Logo
vincent carado Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
At what outdoor temp does the unit stop heating. model lsn186he
Anonymous
Level 3:
President:
  • Master 1,489 Answers
  • Posted on Jan 08, 2011
Anonymous
Master
Level 3:
President:
Answers
1489
Questions
7
Helped
765723
Points
4966
Operating Range Cooling Operating Range: 23° - 115°F Cooling Operating Range with Low Ambient Kit: 0° - 115°F Heating Operating Range: 14° - 75°F Cooling Thermostat Range: 64° - 86°F Heating Thermostat Range: 60° - 86°F
Hello I have carrier v roof top heat pump with furnace unit but one morning stop working and green light 7 times brink please help me any solve problem thank you.
As you may know, heat pumps will not work in extreme cold outdoor ambience temp. It is why the aux heat is there as a supplement.
7 blinks indicates a furnace roll out switch problem. Lack of airflow, lack of combustion exhaust flow, switch fatigue, clog on air filters. The roll out switch senses fire overheating the heat exchanger box and if the temp exceeds the switch (thermal switch) operating temp, then the switch activates and stops the fire and triggers the alarm.
Outdoor model # LSU243HLV Indoor model # LSN243HLV Spli air conditioner looking for error code CH 38
I can not find a 38 anywhere. If I had to guess it would be a temp sensor. Be sure the filter is clean, pull the disconnect out at the outdoor unit for 10 seconds and reinstall. You may find the 38 on the underside of the top panel on the outdoor unit. Best Wishes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2answers
How do we set the outside temp?
since this question is very non specific i.e., no brand name, model or serial numbers, I can only assume that this is the type of unit that monitor the outdoor temp and does not require any settings. If you need more info, please include more details. Thanks.
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
2answers
1helpful
No heat when outside temp low When outside temp is 38 or above get heat. Is there a heater in the compressor that can fail?
I would start with your outdoor thermostat located in
the unit outside. I`m assuming this is a heat pump.
When the outdoor temthermostat is set to say 40F
anything lower than that and you are not using the
compressor, you are using electric heat thats located
in the air handler unit in the house.
I`m also assuming this is a split system and not a
packaged unit. If you are mechanically inclined and
you can locate the outdoor thermostat lower it below
the outdoor air temp and see if the unit comes on.
Sounds like you might have a problem with your electric heat or emergency heat
During heating (outside temp. 2 deg C), outside
Get the charge tested, check the sub-cooling across the outdoor coil.
Breaker keeps getting flipped off
20kw heat should have 2 separate 60 amp circuits on number 6 wire.
Phkj048-1
If the outside temp. is lower than 32 deg. F it is normal for the outdoor unit to build up ice but not safe for the motor compressor. Because the safe outdoor temp. in heating is 5 to 64 deg. F but don't worry it has safety device to stop the operation.
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
