Archos 70 Tablet PC Logo
Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My archos 70 is frozen. not responding to anything and do not know how to reset or shut it down or reboot it. Any suggestions?
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on Jan 08, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
0
Helped
41399
Points
496
2answers
I was reading a novel on my kindle when the screen froze up. I tried to reboot by holding the off button for one minute, to no avail. What do I do now?
Suggest to be sure your Kindle is charged up. There are several generations of these devices. Search for reboot procedure online for example ... "reboot kindle 3rd generation".
1helpful
2answers
HOW DO I UNDER FREZZER MY KINDLE
Hold the power switch for 20 seconds. Slide the power switch and hold it in place for 20 to 30 seconds before releasing it.
  • You need to physically hold the power switch in its off position for this long. Doing so tells your device to "reboot," in essence, instead of merely shutting down.
  • The reboot screen should appear as soon as you release the power switch.
Give the Kindle time to reboot. The Kindle will reboot within a minute or two. Be patient and give your device ample time to finish its reset.
  • There is some possibility that the Kindle will freeze as it reboots. This may be the case if your Kindle stays frozen on the reboot screen for more than ten minutes.
Charge the Kindle. If the device freezes during the reboot or does not respond to the reset at all, plug the charger in and allow your Kindle to charge for 30 minutes or more.
  • Make sure that your Kindle has enough time to complete a full charge.
Hold the power switch down again. After you finish charging the Kindle, slide the power switch and hold it down for another 20 seconds.
  • The reboot screen should appear again. Give the device a minute or two to reboot before checking it again. This should complete the reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Shutting itself down
Make sure the charger is plugged in before attempting this. If already plugged in or same thing happens then you can try and follow the guide as below to do a hard reset:
http://www.mobicpc.com/how-to-hard-reset-archos-97-titanium-hd-to-factory-default-setting.html
If still not able to reset, poss hardware issue
Thanks
2answers
Kindle Fire
Press and hold the power button for fifteen seconds or so. If it prompts whether you want to shut down, ignore it and keep the power button pressed until it shuts off. Release the button, then press and hold for a second or two until it starts to reboot. Does it reboot and operate normally now?
Archos problem
Help, my Archos A70h is stuck on recovery the white page, it won't boot, how can I get back to the home screen.
Wont turn off or respond is there a reset somewhere ?
Hi there. A reset is done on this tablet by holding the power button for at least 10 seconds. hopefully this will reboot it and it will start responding again.
9helpful
4answers
My tablet froze... how can I unfreeze it?
if its anything like an samsung tablet hold the power button down for atlest a min. I had to hold mine down for 30 seconds to get it to reboot
Top Archos Tablets & eReaders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
