Question about GE Freezers
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
    President:
  • 2,468 Answers
Remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Posted on Jan 08, 2011
SOURCE:
Hi all My fridge freezer seems to have a problem.
increase the thermostat to a more cooler one, ideally at -5 F
Jan 02, 2011 | Freezers
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Not Cooling Fridge Or Freezer keeps Freezing up (New Defroster)
There are 3 parts to the defrost system,Which did he replace? You should ask and don't name the parts for him,Let him tell you what he replaced.Here are the 3 parts to listen for.
Improper installation,a faulty part,or a short could cause it to fail in that short time.
  1. Defrost timer
  2. Defrost element
  3. Defrost thermostat.
Any other question, feel free to ask
Please rate this a fixya
May 18, 2009 | GE Freezers
Fridge not cold
I had the same problem with fridge/freezer and repair man told me NOT to use anything that has been in freezer as what is happening is that it is constantly freezing and defrosting because there is not enough gas in the system to cool the appliance. It is possible to re-gas the appliance but service engineer advised me to claim a new fridge/freezer from company which I did. Please do NOT eat anything from freezer as could make you ill.
May 01, 2008 | Freezers
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
246 people viewed this question
Top GE Freezers Experts
craig nesmith
Level 1 Expert
AJMAL KHAN
Gil Shultz
Are you a GE Freezer Expert? Answer questions, earn points and help others
