Timer is stuck on 'auto 0.00'. Reset button does not clear the problem. How do I clear this?
Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED!
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
TIMER STUCK AT 0.00 AUTO AND OVEN NOT IGNITING
timer on zero and no gas coming through so ovens wont ignite
Clock keeps going back to 00.00 and flashing and then has auto written down the side and the oven won't light.
can not get top unscrewed to lift off as screws will not budge have clock flashing auto ooo, i can not change this, as you have described.
