Jenn-Air JGR8850 Gas Kitchen Range Logo
Tawny Kennaugh Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My oven is very slow to heat up now. It takes an hour or more to heat to temp.
Sal De
Level 3:
  • Jenn-Air Master 2,699 Answers
  • Posted on Jan 08, 2011
Sal  De
Jenn-Air Master
Level 3:
Answers
2699
Questions
0
Helped
1002383
Points
8029
You need to change out the bake ignitor.when the ignitor is breaking down this is what happens,it takes longer and longer for it to ignite the flame and i've seen some ignitors burn a hole in the tub,change out the ignitor and you'll be all set,part number 74007498.
Blodget zephaire G takes 2 hours to reach temp.
It hard to tell, please let me know what did you see and hear when turn on oven...
Electric oven is very slow to heat up, and gives false temp. why?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Oven temp
I am experiencing the exact same problem. May try to trouble shoot myself if no one provides assistance on this site. It looks like the problem has to do with either the Sensor, Heating Element or etc..
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
7helpful
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
2helpful
2answers
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
5helpful
Oven slow to heat
An extremely common problem on these models is a weak silicon carbide ignitor. You may be able to see the ignitor glowing, but that is not an indicator of it being functional or not. When the ignitor gets "weak" over time, it will not create enough amperage in the circuit for the gas valve to open. You can test this using an amprobe around one of the ignitor leads and looking for at least 2.9 amps, but years of working on these appliances has shown that if you are getting the glow from the ignition but the oven is often slow to come on, you need a new ignitor. Do-it-yourselfers often mistakenly replace the oven valve or the oven temp sensor, figuring the ignitor must be good because they can see it glowing.
Replace the ignitor and your oven will work great again.
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
