HP DeskJet F380 All-In-One Printer Logo
Posted on Apr 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot insert my HP 21-22 ink cartridges. I try and try, and end up asking my neighbor, and they just "fall" right in for them. What am I doing wrong? I just dread when the ink level gets down and time to replace, as I have this everytime. I hold the printer so tight and push for all my might, and they don't? I do slightly tip it's back up and slide in the bottom and it is supposed to snap in. NO go for me. Help. IF THERE IS A CHARGE FOR THIS, I DIDN"T SEE ANY, THEN DO NOT RESPOND WITH YOUR ANSWER BUT PLEASE NOTIFY VIA MY E-MAIL THAT IT COSTS ME????
richie46
Level 3:
Top Expert:
  • HP Master 12,962 Answers
  • Posted on Apr 25, 2017
richie46
HP Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946044
Points
58151
Listen, so you are a tad clutzy. Swallow your pride and continue to let your friend help you out. U would do it for him, wouldn't you?
5 Related Answers
sagarjd
JD Kiran Sagar
  • 95 Answers
  • Posted on Aug 01, 2008
SOURCE: Problem with HP PSC 1415 printer on inserting refilled ink cartridge
Check this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00005109&dlc=en&product=441115
Regards,
Sagarjd
Anonymous
  • 8 Answers
  • Posted on Mar 14, 2009
SOURCE: 4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
[email protected]
Anonymous
  • 214 Answers
  • Posted on Apr 23, 2009
SOURCE: C7280 printer wont recognize newly inserted ink cartridge! HELP
Try cleaning the gold contacts on cartridge with DISTILLED water and cotton bud, allow to dry and reinsert. Make
Anonymous
  • 7 Answers
  • Posted on May 27, 2009
SOURCE: Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
Anonymous
  • 111 Answers
  • Posted on Apr 13, 2010
SOURCE: HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Greetings, I have a Canon Pixma M610 and this problem just started happening. Everytime I replace an ink cartridge, the new ink color doesn't print AT ALL until I run a "deep clean". Then,...
Try removing all ink cartridges and printhead from the printer. Then, look inside the printer with a flashlight. Look into the right side of the printer and see if there is lots of ink gunk. Remove if any and try not to leave ink gunk on other printer parts. Turn printer off when removing ink gunk. Then after you are done cleaning, turn printer on and wait for it to command you to insert printhead. Do that and close cover. Then, insert cartridges when printer asks for them. Hope that helps. -Alex
303Electronics eBay Stores
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
5610 hp printer shows insert cartridge on right when i changed to new cartridges. they are new cartridges and are inserted correctly
try this
- Remove the cartridge that is not working. - look for a lint free cloth "coffee filter" then dump w/ water - clean the copper contacts of the cartridge - make sure that the air vent is open; if not pinch it a bit - remove all the cartridges - check if there are are inks spills - use lint free cloth to clean the part where you are have trouble with - install the inks again - run alignment and clean cartridges on the panel
if still nothing works, call HP tech support and ask for replacement of the ink.
note: they will do the same steps again for troubleshooting and documentations. the reason why this happens: - that the copper contact does not touch each other - cartridge air vent is sealed - not an orig HP ink - Print head problem, needs cleaning
4helpful
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
1helpful
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Neighbors printer is an HP 1610 "All in one". I cannot figure out where to put the replacement ink cartridges.
The person found the manual. With the printer ON, you simply lift up the top portion of the printer (under the scanning screen) from the front, and the ink cartridges move to the right for you to replace.
5helpful
2answers
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
4answers
Print cartridge in right stall not supported
Are these genuine HP ink. If not try using Original ink.
If its already the original ink then check the Exp date of the ink and try cleaning the copper contacts of the ink ( not the nozzles ) of the ink and the printer
All the best
k24674
Grand Canyon Tech
Grand Canyon Tech
