Question about Ricoh FT5832 Copier
How do you remove the hard drive (memory) from a Lanier model 5635 copier?
    New Friend:
  • 111 Answers
FT 5832 is analog copier their is no hard drive for analog it just present digital copier.
Posted on Jan 09, 2011
2 Suggested Answers
SOURCE:
  • 2072 Answers
SOURCE: We have a Lanier Copier
yes it does. the hard drive is located on the left side in back of the machine, It is easy to remove. If you are trading it out, you can either remove it yourself or have a service rep remove it.
I have done that several times for customers who do not or can not allow hard drives to leave their presence.
Posted on Feb 23, 2011
How do I Remove the hard drive from Lanier printer model number LD445C
It is located behind the panel where your Ethernet cable plugs in. The easiest way is to remove the rear panel. Then remove the metal panel. From there you should be alright on your own.
Oct 14, 2014 | Ricoh Lanier Ld445c Ld435c Ld430c Magenta...
Sc542 error on lanier
That is a dirty thermistor in the fusing unit.
Apr 14, 2014 | Lanier 2045 2145 5635 5645 Toner 23 000...
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
We have a Lanier Copier Model 5635 and we need to know if saves PII information on a hard drive before we can remove it from our office.
Feb 22, 2011 | Ricoh FT5832 Copier
Why is my Lanier 5635 display screen dark?
On the left of the operation panel you have the dial contrast. Try to adjust that. If doesnt work problably you have a broken LCD
Feb 16, 2011 | Lanier Office Equipment & Supplies
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
How do I remove the hard drive from a Lanier LD328c. This needs to be done for security reasons.
You should contact a Lanier or Ricoh service technician to remove the hard drives for you, but if you have to do it yourself the hard drives can be removed by unscrewing and sliding out the controller board (on the right side of the copier). The hard drives are connected to the controller board by three screws and four connectors.
Sep 23, 2010 | Lanier UNKNOWN
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
How can I find a schematic design of Lanier Model 5635/5645 Copie
Goto my website and Download the file from the Public Folder. It is the only Point 2 Point in the folder.
Do not forget to vote Yes or No if this information was helpful
www.copytech21.spaces.live.com
Apr 01, 2009 | Lanier Office Equipment & Supplies
Meter reading
2 ways to check the meter.
press the user tools button on the op panel. on the screen press counter. you can either view the counter on the screen, or press print counter, and it will give you a hard copy.
the 2nd way is to look behind the front cover, probably behind a piece of tape, on the right side, about half way down.
Nov 20, 2008 | Lanier 1205 Copier
Ricoh FT5832 Copier Logo
327 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
