Purchased this unit at an auction.Coffee machine works but coffee is weak.When we put 12 cups off water and 12 spoons of 12 coffee in coffee brews but is weak.Need to know correct mixture?do we put water in every time we make coffee or can we fill tank to make multiple pots as we have three.
Thank You in advance.
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Also the "cup" measure on different makers is not the same between brands. A standard "coffee cup" is 6 oz instead of 8 as in a fluid cup. A commercial pot holds 12 fluid cups to a fill line about at the level of the top of the printing but the pot actually holds 16 fluid cups when filled to the top so more coffee would be needed to make the same strength.
What's a "spoon"? What's a "cup"?? It takes 2 tablespoons of proper grind coffee per 5 oz cup to make proper coffee! I'm amazed that people make and drink coffee water instead!
bob
