I up loaded some files (from a PC) and I can not play them back on the recorder. The display does not show any new files on any folders. When I hook the recorder back to my PC it shows the files and it can even play them. How can I listen to the up loaded files on the recorder?
Recording Company Greeting
1 Press FEATURE 9 8 3 The display shows
Log:
QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK The display shows
Admin
MBOX AA OTHR
4 Press AA The display shows
Auto
Atdt
Admin
GRTG
TABLE
LINES
5 Press GRTG The display shows
Greeting Admin
GRTG AA
6 Press GRTG The display shows
Greeting:
RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK The display shows
Greeting
RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting. Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording. The display shows Accept Greeting: RETRY PLAY OK NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play 1 From Step 12 press * 2 Press Table
Auto Atdt Admin
GRTG TABLE LINES3 At Grtg table: enter 1 4
Grtg table:
Retry OK 5 Press OK 6 Press OK again @ AA menu prompt 7 At Morning: 1 press CHNG to whichever new greeting you recorded CHNG
Morning:
PLAY
NEXT 8 Continue by pushing next through all times 9
Afternoon:2
CHNG PLAY NEXT 10 You should note which times had which greetings to change back after holiday 11 After you change all the times Morning Afternoon Evening Non-business press Release ------------------------------------------------- This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
It may be the file type that you've saved is not compatible with your DVD recorder.
Check the instructions on your DVD recorder, see what kind of files it plays ie JPEG, MPEG1 and MPEG2 then either save your file as one of these or download a file converstion programme from Filehippo.com such as :- Any Video Converter 3.05
for free.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT) If you format the recorder, all function settings will return to their defaults. All files stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. 1 Press the MENU button. 2 Press the FF or REW button to choose “FORMAT”. 3 When the PLAY button is pressed, “nO” is displayed. 4 Press FF or REW to select “yES”, and press the PLAY button. After “ARE yOU SURE” is displayed, “nO” will be displayed. 5 Press FF or REW to select “yES”, and press the PLAY button. “DONE” displays when formatting ends. s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach the battery compartment from the recorder during that time. Otherwise data may be damaged. s Never format the recorder from a PC. s When the recorder is formatted, all the stored data, including locked files, are erased.
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back or stop function
+ i can only stop rec by removing batteries (stop or play will stop rec only ONCE - but there is no useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual with no effect
+ i cleaned the spring contacts inside battery compartment that interface with the batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )
it was inside a drawer
THANK YOU
I think I know your problem, but if it doesn't work I'm sorry. I'm not the best when it comes to technology. Don't play it while you're erasing and hold down the erase button 'til you here a beep. I hope this works.
