Good day !!!
may i have a quuestion to you regarding my problem on how to set up the linksys broadband router 2.4 ghz 54 mbps through my loptop? pls answer me asas pls.!!!!
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Follow the steps to setup your linksys router:
Connect the Cable modem to the router's WAN or Internet port.
Connect a computer to any of the router's numbered ports (1, 2, 3 or 4). If you are using a wireless computer, you will need to connect it first with an Ethernet cable.
Connect the power adapter of your router to the power outlet.
Access the router's web-based setup page. Open any web browser such as Internet Explorer, Mozilla Firefox or Safari. Enter "192.168.1.1" in the address bar then press .
You will then be asked for your login details. Leave the User name field blank and enter "admin" in the Password field then click OK.
On the Linksys Setup tab, click on MAC Address Clone.
Select Enabled then click on Clone My PC's MAC.
Click Save settings.
SOURCE: may i have a quuestion to you regarding my problem
you need to configure your linksys router. to do this
connect to the router with a cat5 cable in any of the lan ports.
open internet explorer and go to the http://192.168.1.1
the default login/pass login : blank pass: admin
if you had changed this before please use that login/pass. or reset the router if you can't login by holding the reset button for 30 secs.
once you login go to the wireless button.
there you can set the SSID of your wireless network. this will be the name of your wireless network.
then go to wireless security to set the security to WPA.
choose a good passphase that you can remember.
apply the settings you had made.
on your laptop unplug from the router and search for a wireless network. you should see the ssid name that you made.
connect to it and it will prompt you to input a wireless password.
put the passphase that you setup for your wifi.
you should now be able to surf the internet wirelessly.
I im using the Wireless-G 2.4 ghz, i was using it perfectly buy from to days ago until now y cant wet any signal
how to set up the wireless -G 2.4 ghz 54mbps LINKSYS
