SOURCE: Frigidaire Oven Problem
please post the model Number here..so i can look it up but just off hand there maybe an oven sensor (thermistor) problem this in inside the oven and tells the electronic ctrl board what the actual temp is in the oven it says 135 beacause it will until the temp reachs that after that as the temp goes up it will read 140 150 160 .. and so on until it reachs the set temp .. Is the oven getting hot and are there any fault codes coming up??
SOURCE: Electric Oven is not heating up (BAKE)
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
It could be that your lower element is burnt out or ready to
burn out. They last 3-5 years depending how much you use your
stove.
Disconnect POWER to the stove, remove the screws holding the lower element to
the back of the inside of the stove, pull out carefully and remove the 2 screws
holding the wires on. Check the element with an ohm meter, it should read
0 (zero or very close) resistance on an ohm meter. You may also take it
to a store that sells replacements ($25) and they may check it for you.
SOURCE: My Dacor wont heat, broil or convection after self cleaning
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
SOURCE: dacor oven won't preheat and
It worked for me but it was not like I was pushing the red button in. It seemed to be in the same place before and after I reset it.
