How To
Unlock Tesco Internet Phone Siemans DP450
Unlock your Tesco DP450 IP Phone to use this with other VoIP providers.
Gigaset Communications have created a process that enables Tesco
Internet Phone subscribers with Siemens Dual-Phone DP450 to unlock the
phone from the Tesco Internet Phone service. This will enable the phone
to be used with other Internet Telephone services. This follows the
recent news that the Tesco Internet Phone service is to be ceased from
April 26th, 2010.
This is an approved method for unlocking the Siemens Dual-Phone DP450
defined and released by Gigaset Communications, the original supplier of
the phone to Tesco.
If this procedure is not followed exactly your phone might not
work anymore. In this case Gigaset Communications cannot
accept any warranty claims.
Unlock
procedure
Your Phone should have the latest released Tesco software version, else
this unlock procedure will not work.
On your handset:
BASE > SETTINGS > SOFTWARE UPDATE
Select and press
OK Enter the
system PIN (0000) and press
OK
The base station establishes a connection to the internet or a local PC.
YES Press the display key to start
the firmware update. If no update is needed, this will be displayed.
To unlock the WEB interface of the DP450, you need to enter the
following service code. Please use the exact code as is described below,
else your phone will not work anymore.
SETTINGS > BASE 94762001 (Now
"Eeprom" must be displayed)
Insert the following number sequence:
01778
06183 06191 Press
OK to
finish the programming.
"Saved"
must be displayed on the Handset.
Then release the phone to be able to upgrade it with the latest Retail
firmware version.
SETTING > BASE 94762001 (Now
Now insert this number sequence:
04850
04351 04864 Press
OK to
"Saved"
After this procedure you can upgrade your phone to use the latest retail
firmware version.
SETTINGS > BASE > SOFTWARE UPGRADE
Select and press
OK Enter the
OK
Please Note:
The firmware update can last up to 3 minutes.
Your Phone is by default configured to use the Internet Telephone
service, if you want to change this to set the default to the land line
you need to change this in the web interface from your phone. How to do
this, download the Gigaset S450 IP manual from the Gigaset web-site URL:
http://gigaset.com/uk/en/cms/PageCustom ... nuals.html
Regards,
Smith Online
on a LG 3.0 smart phone how do get rid or delete everything i've searched or ask or called
