I don't understand why you are plugging this into a 110 volt regulator.. If by chance you are trying to run this from 220 volt power, you DO NOT use a regulator or a converter intended to run hair driers and appliances. You need to use a step-down transformer from 220 to 110 or 240 to 120.
The V\Amp2 is a switching regulator and it will NOT like to be run from another switching regulator such as found in those cheap appliance type convertors.
Here is the type you need: http://www.world-import.com/tc-100a.htm
I cant plug my 120v
Problem with the Behringer VAmp 2 Power Supply:
Im sorry, i spaek better spanish
Loque pasa es que quando hay mas equepo conectado en la misna red de eletrcidad saliendo del enchufe del muro (120v) se baja la capasidad i el V- amp2 se apaga.
Por ese motivo compre un regulador pero el regulador tiene una salida de 220v i 110v
[email protected]
