When trying to launc;h sing plaoyer in CoD 2 the error "please insert the correct cd/dvd rom press ok the restart the application"...dvd is clean and free of scratches, I have changed campatibility mode to 98se sp2, and run the program in as administrator...what needs to be done to fix this problem?
When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
If you are prompted with a Microsoft Windows boot screen, press the Enter key.
After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
Restart the computer.
When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
Press the CD-ROM drive eject button and insert the disc labeled System CD.
Close the CD-ROM tray.
Refer to on screen instructions to select either CDROM or USB CDROM.
The computer will boot from the Recovery Media
When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
The game need the play disk... you must insert the play disk into your CD ROM.
or
browse the content of the CD, try to find the crack folder. Click -->"Browse"--> go to the folder named--> "Crack".
Inside that folder, you will find an--> ".exe" file (the executable
of the game)-->"Copy" this file to --> the folder in your HDD,
where you have installed the game.
IF YOU PUT OTHER DISK IN AND IT WORKS - AND CD - AND IT WORKS YOU EITHER HAVE A BAD DISK OR YOU DO NOT HAVE A DVD AND YOU NEED A DVD TO WORK THE GAME TRY COMPLETELY REMOVING THE CD - DVD PLAYER YOU HAVE AND REBOOT WITHOUT IT - THEN FIND AND REMOVE THE DRIVERS - THEN REINSTALL IT. REMOVE THE CD - DVD PLAYER AND DRIVERS ONLY IF YOU'RE RUNNING WINDOWS XP AS AN OPERATING SYSTEM. BEST OF LUCK WITH I T
You need to do a complete uninstall since most uninstall programs leave lots of junk behind and fool the computer into "thinking" that the software is still installed.. See if manufacturer has software available (EX - Norton has sit) that does a complete uninstall. If not you will have to get brave and to into the registry using regedit to remove all vestiges of the program and then reinstall it. Good luck.
Or try a system restore point that was generated BEFORE the date of your original install of the program!
