I can think of some actions to play with (in case you haven't already taken them, that is):
1) on your phone, go to 'Start > Settings > Connections tab > USB to PC' and toggle the 'Enable advanced network fucntionality' checkbox, i.e. it it is checked, uncheck it; otherwise, check it. Try to connect. Then, restore that setting to its original value and try again;
2) For security reasons, backup your PIM first (you could just copy file 'pim.vol' on the root of your phone to your SD card, to be copied back to the rooot of your device later). Then, delete the sync partnership, both on your phone and your PC. and try to set it up all over again;
3) You could try to uninstall and reinstall WMDC on your computer.
Really hope you are able to sort your problems out. Anyway, please, let me know if I can help you any further.
Regards,
Carlos
Insert the "Getting Started" CD that came with your device into your PC and follow the prompts.
Note: The disk will detect what operating system you have and what sync software you have loaded. If you already have ActiveSync installed on your PC, it will not give you an option to install it from the disk (same for WMDC) until it has been removed from your PC.
The phone reboots after install.
And done
