Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Note, electric
mixers are great to have around, whether the stand or hand-held type.
For those of us that use one on practically a daily basis, here are few instruction below on how to fix an electric mixer.
Instructions
Unplug
the mixer before attempting any type of repair. If the mixer has a lot
of batter and food on it, clean the appliance. A lot of times while
using the mixer, the ingredients can work their way up the beaters and
make their way into the gear section where the beaters attach. This can
happen especially when mixing bread dough, cookie batter or any dense
or heavy ingredients.
Refer
to owner's manuals when fixing an electric mixer. If the mixer stops
beating when it's turned on, it could be that the appliance isn't
getting the proper voltage. Test the mixer using a voltmeter. If the
mixer is getting the proper voltage, it could be that one of the gears
are worn out.
Check
the wiring on the mixer. Look for any cracks, tears or exposed wires.
Sometimes just using electrical tape to repair the cord is all that's
needed.
Take
out the screws from underneath the head of the mixer using a Phillips
screwdriver. Next take out the screws on the back of the head of the
mixer (some brands have these, others don't).
Grasp
the head of the mixer and gently pry off the housing with a large
screwdriver. A slot screwdriver is preferable. Clean out the area with
a soft cloth and look for any broken parts or wires.
Go
directly to the website of the brand of mixer you have. Most major
brands will offer advice and suggestions for proper maintenance.
There are lots of places to be looking, first thing I would look at would be under the rear cover to make sure the two nuts that hold the rear motor bearing housing in place are nipped up. You don't wring the neck on these nuts, if you over tighten them you will deform the rear bearing housing.
If you can find someone local who has been doing these mixers for a while they will be able to give it a once over. It's unlikely to be expensive. Best people to ask is Kitchen Aid, they should know who does their warranty work in your area. If you are in new Zealand it will be me.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
You are overloading the bowl or you bought this used and when they wore the motor out, you ended up with it. Batters & icings 75% bowl capacity, doughs 65% bowl capacity. If you live by this, you will buy 1 mixer & never have to replace it, especially if it's a Hobart.
make sure you are using the right attachment. usually for batters you want to use the flat beater. not the dough hook. the flat beater looks like a triangle with lines through the center. and make sure you are using the correct speed on the mixer. start out at stir and then go up to no more than half speed. these mixers take a little longer to incorperate batters but they do a very good job at it. if the batter is thin enough you can try using the wisk as well. but only if it is a thin batter.
I had the same problem the first time I tried to make a small batch of bagel dough (very small!) I had to send it back for repair and wait.....sorry that the news is not better.
