SOURCE: ice maker leaking water after replacing the solenoid valve two times
maybe the solenoid stays on too long during the fill cycle.. broken gear maybe or out of adjustment
SOURCE: ICE MAKER NOT WORKING
Yes, the ice maker controls the water valve. First check that there is water in the ice maker trays. If there is your valve is not the problem. If not, loosen the fitting on the water line that leads to the water solenoid valve. If you do not find water, check your manual valve that taps into the main water line. If you do have water, it may be that the water inlet above and behind your ice maker is frozen. You can thaw it out with a hair dryer and see if that is the problem. If this model dispenses water through the door, you can find the water solenoid valve behind the unit near the floor and reverse the two plugs on the solenoids. Place a paper towel in the water inlet tube that channels the water into your ice maker. Close the coor and press the water dispenser for 3 seconds. Open the door and see if the paper towel is wet. If it is, the water solenoid is fine. You can also remove the front of the ice maker and put an insulated jumper wire between the T and H test points to see if the unit ice maker will go through its cycle.
SOURCE: Ice maker not working
It's possible that the tube that supplies water to the ice maker is blocked with ice (freezer temp. too cold) and not allowing water to get to the Ice tray.
You can squeeze the tube to see if it's iced, and if so you can melt the ice with a blow dryer and adjust your freezer temp. to the manufacturer's suggested setting and work from there.
I have seen this happen, but there are other problems such as just a broken ice maker too.
Good luck.
SOURCE: Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
