Question about Sony Ericsson Stereo Bluetooth Headset HBH-IS800
Hi, I Just bought a sonyericson bluetooth headset HBH-IS800 after pairing it with computer thinkpad t400 using windows 7 it tells me that windows update can not find the driver can you tell me where i can download the driver from as i can see the had set in my devices but cant use it thx Moshe
5 Suggested Answers
SOURCE:
SOURCE: pairing
read the manual page 64 bottom right corner
Posted on Jul 30, 2007
SOURCE: please need help urgently
You should press both + and - button on your head set and wait until green light turns into red.
Posted on Aug 03, 2008
SOURCE: Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
Posted on Jan 13, 2009
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
Posted on Jun 07, 2010
I am using xperia X10...and i want to connect to my HBH-GV435 bluetooth to this phone..but the HBH-GV435 blue tooth is already paired with some other phone.so i want to reset the bluetooth and connect it...
Headset-
1. Make sure the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
2. Press and hold the On/Off button for at least five seconds, until you hear a long high-pitched beep and the light flashes red and green. The headset is now in pairing mode.
3. If your phone supports auto pairing, press "Yes" when the question Add device? appears in your phone. If it doesn't, continue with the next step.
4. Prepare your phone in accordance with the phone instructions for adding a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
X10-
1. From the Home screen, tap the applications bar.
2. Tap Settings > Wireless controls > Bluetooth settings.
3. Mark the Bluetooth check box.
4. The phone starts to search for the device. Make sure that the device is in pairing mode. If needed, tap Scan for devices.
5. When the device becomes visible in the Bluetooth devices found list, tap to select it.
6. If needed, tap the text bar to enter the passcode (0000 by default) and tap OK.
7. You can now start using the paired Bluetooth device. The status of the pairing and connection is shown below the name of the Bluetooth device in the Bluetooth devices list.
Good Luck!
Mar 23, 2011 | Sony Ericsson HBH-GV435 Bluetooth Headset...
I am connected bluetooth device HBH PV705 in computer windows 7 . Device not connected bluetooth driver (bluetooth peripheral Device) not updated. please help me, wat can update plz send sit link
run microsoft updates on your computer 1. control panel 2. system and secruity 3. windows updates f that doesnt work to the manufators website and download the date drivers hope this helps
Jan 06, 2011 | Sony Ericsson HBH-PV705 Headset
I'm using a HTC Legend and would like to sync it with my IS-800 but the phone can't seem to find the headset. I thought bluetooth headsets were more or less universal. Is there anything i can do?
For some phones, provided that both its bluetooth radio and a nearby BT headset are turned on, and the headset's MFB (for the IS800, the only button it has) is briefly pressed. The phone then prompts the user to pair with the headset. For others, the headset must be put in pairing mode, and the phone must be made to search for it. If this is your case, press and hold the IS800's button until the right earpiece's led flashes red / green (the white led, next to the mic, will flash too). Then, you must start your phone's bluetooth settings, and make it search for the headset. In both cases, if you are prompted to enter a pairing code, the IS800's is '0000' (four zeros).
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 26, 2010 | Sony Ericsson Stereo Bluetooth Headset...
N97 connectivity problem with bluetooth HBH DS 200
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 08, 2009 | Sony Ericsson HBH-DS200 Stereo Bluetooth...
I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
Jul 14, 2008 | Sony Ericsson HBH-610a (Auto Pairing)...
Hbh-pv705
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Nov 27, 2007 | Sony Ericsson HBH-PV705 Headset
P990i is not supporting headset bluetooth HBH-PV700
You must operate your bluetooth headset HBH-PV700 in discovery mode in order for your mobile to discover the headset and then pair the two devices. To activate the discovery mode of your headset, while it is switched OFF press the switch on button and leave it pressed for approximately 10 seconds, then search for it with your mobile and pair the devices. most of the times the code needed for pairing is 0000 (zeros)
Oct 03, 2007 | Sony Ericsson P990i Smartphone
K750i
if any one got the solution pleae tell me too hahaha
Jun 04, 2007 | Sony Ericsson HBH-610a (Auto Pairing)...
Pairing
1) Make sure headset is off. 2) Press and hold the answer button until the light flashes green and red. 3) If it only flashes green, press and hold both volume buttons until the light lashes red and green. 4) It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000. 5) All done.
Feb 24, 2007 | Sony Ericsson Universal Bluetooth...
Compatability bluetooth headset K 750i/K800
Hi, The way that I paired my device is by pressing and holding the two volume buttons simultaneously for about 5 seconds, until the red and green lights began to appear. Then, i just 'refreshed' my bluetooth search for devices, and it discovered it, and was able to pair it up. Hopefully, this is useful
Oct 18, 2006 | Sony Ericsson HBH-610a (Auto Pairing)...
Sony Ericsson Stereo Bluetooth Headset HBH-IS800 Logo
66 people viewed this question
Top Sony Ericsson Radio Communications Experts
Håkan Sterner
yobo007
yobo007
Jay Finke
Jay Finke
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
