Your car not going to sleep mode.
Battery power going down and car answered in this problem- car alarm to on,warning lights to on = battery powes shut down.
What battery !! The one in remote or under the hood your !@ 12 volt ?(More Info please)
SOURCE: BMW X5 Battery Drain.
hello theringbar, I would recommend checking the a/c blower resistor. it is an electronic final stage and can kill the battery overnight. the final stage is located on the passenger side at the back of the a/c heater box.
SOURCE: 5 series Battery drain.
Hi, you will need to remove the passenger side kick panel under the dash then you will be able to see the side of the heater box, you should be able to see a black milti plug with a 2.5mm red and white wire, if you unplug this you will see the casing for the resistor, this just un clips from the heater box and remove, replacement is just the reverse, hope this helps or if you get stuck just ask for more help, mark.
Testimonial: "thanks for all the help."
SOURCE: 2003 BMW Car Alarm keeps going off
Hi , you can lock your car without activating the allarm by using the key to lock your car manually ( not the remote ) , the most common alarm fault on this car is the hood switch, if you change this buy one for a bmw Z4 model which is slightly longer and garrentees a contact when the hood is closed, hope this helps regards mark
SOURCE: E36 BMW 318I CENTRAL LOCKING
try locking and unlocking the car with the key 3 times slowly ,other than that i have no idea ?? another trick is to disconnect battery and join the cables together for a few minutes to discharge any capacitors that may be holding a charge in the computer..Only other thing i can think of is the main dealers who have the right connectors and software to re set it all .sorry i havent been of any help
SOURCE: 2003 BMW 325xi won't start, dashboard and radio go on.
My 2003 325xi died on the highway a few weeks ago, and I thought it was the battery. It turned out to be the alternator, which was an expensive problem to repair. If your battery is new, it could be the alternator, or a problem with the electrical system. I find the BMWs to be too complicated electrically, which often leads to problems! I'd check your alternator...
