Print spooler is no less than the main master of printing proceeding.
Print spooler is a linking section between your PC and printing
hardware. Print spooler is the only master of print province of your PC
office. Print spooler can inkle nothing and
encounter an artificial virus threat which will cease your printing
operation and compel your print spooler down on the count. Sometimes to
solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
There are several ways to resolve printer spooler error, probably because there are many variations of this error.
The error caused by faulty software can be resolved by deleting all the information found in the directory.
Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon.
Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program
might be corrupted.
Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another
window.
On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode.
Click Okay, and restart the machine. If you're lucky, this might be all you have to do.
Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel.
Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure
to be thorough about it, or the problem may not be solved.
Download the latest copy of your printer's software from the manufacturer and reinstall it.
