SOURCE: Toshiba SD-43HK Discs failing to load.
Sorry not a solution but experienced the same problem. The problem started off the same as you described by now my player won't play DVDs at all. Seems that the laser is faulty and it is cost prohibitive to repair (it's sold as a complete module which would be around £100). I've been advised to replace it :-(
SOURCE: CD plays CD's intermittently does not recognise some CDs
in my side i already encountered that problem.this is what eve done,i'm just clean the lens with cotton and one drop of alcohol, after cleaning,its work.....just follow what i'm doing....
SOURCE: SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
SOURCE: My Toshiba SD-3960 sound does not work.
My Toshiba DVD Player does not work. I can not watch online movies. What I ca do? Please send me if you have any suggestion.
Thank you.
SOURCE: Karaoke CD's will not play on Craig CD+G player
This is a problem with a simple answer. As newer disk technology comes out, newer electronics come out to work with them. Most likely your Kareoke machine is older and not compatible with burnt cds. As long as you are ok with buying regular CD+G disks, you should be fine. If you are interested in making or copying CD+G disks from others, you should consider investing in a new Kareoke machine. As per your question of it being correctable, to my knowlege, No. The electronics in older kareoke machines are not meant to handle CD-Rs or CD-RWs and in order to correct it you would have to somehow frankenstein a new circuit board in somewhere to allow it to handle CD-R/W Disks. As I don't know what is necessary, I am not sure if this is even possible. Like I said if you need this function, you are better of just getting a new Kareoke machine and selling your old one to offset the cost. Make sure the new one handles CD-R and CD-RW disks. Some more expensive ones will also handle Kareoke DVDs as well and have an A/V out so you can display the information on your TV(some of them will even handle DVD-Rs as well). Just look for that information on the box or ask a store representative for that information and they should be able to help you.
