Kenmore Freezer 11.6 cu. ft. Upright Freezer Logo
Posted on Jan 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need manuel for a Kenmore frostless quick freezer model #253.9280410
Dan Webster
Level 3:
  • Kenmore Master 8,221 Answers
  • Posted on Jan 07, 2011
Dan Webster
Kenmore Master
Level 3:
Answers
8221
Questions
5
Helped
2379095
Points
25840
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:need manuel for a Kenmore frostless quick freezer - themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesneed manuel for a Kenmore frostless quick freezer - themobilian_748.jpgimages/themobilian_748.jpg" alt="themobilian_748.jpg" class="h_mi" />The compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause dneed manuel for a Kenmore frostless quick freezer - themobilian_749.jpgad.Not much to thneed manuel for a Kenmore frostless quick freezer - themobilian_750.jpgg src="/uploads/images/themobilian_749.jpg" alt="themobilian_749.jpg" class="h_mi" />themobilian_750.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My Kenmore 18.0 Frostless Series 62801 with 18.0 cu ft has a broken freezer thermostat and the freezer only holds a temperature of about 32, which doesn't cool enough. HelP!
If freezer is only 32, it’s probably freon or compressor related problem and not the thermostat. Or possibly a defrost problem.
Older model frostless freezer model number 2539280411. The temp alarm light is blinking.
Is the temperature warmer as well, or is it just the alarm light blinking?
11helpful
2answers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
2helpful
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
