Take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
Testimonial: "thanks. thats worked. will i have to use a dell battery or can a compatible one be found"
Have you tried to boot the laptop with the battery out and just the charger plugged in. Most dell laptops will power on without battery and just charger give it a try.
Let me know if this helps
Robert
If you can find a compatible one it should work but if your laptop is under warranty you might be able to get one from dell. Also the compatible one usually don't last as long. To help extend the battery you should unplug the power and let the battery run all the way down at least once a week.
Robert
SOURCE: i have a dell inspiron 1545. i have the charger
yes plaese buy a dell battery.. for further details you can visit the following site
support.dell.com
Testimonial: "cheers :)"
thanks. it's turned on without the battery.
do i have to buy a dell battery or will a compatible one(if available) do?
