Computers & Internet Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot find info or the card on how to install drivers and afterburner disk. Video card is MSi N220GT-MD1G. says the device is 0a20.. onboard number is N1996. Just need to find card info on installing, need to know what the hardware requirements are, power etc. help to install the card and setup all the drivers and the afterburner disk. thank you. Bobby
john morgans
Level 2:
Sergeant:
  • Expert 339 Answers
  • Posted on Jan 06, 2011
john morgans
Expert
Level 2:
Sergeant:
Answers
339
Questions
Helped
127190
Points
999
  • Manufacturer: MSI Computer Corp.
  • Part number: N220GT-MD1G
General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Interface Type PCI Express 2.0 x16
Processor / Memory
  • Graphics Processor / Vendor NVIDIA GeForce GT 220
  • Clock Speed 625 MHz
  • RAMDAC Clock Speed 400 MHz
  • Video Memory Installed 1 GB
  • Technology GDDR2 SDRAM 128-bit
  • Memory Clock Speed 810 MHz
  • Features Nvidia PureVideo HD technology, Solid aluminum capacitors, Nvidia CUDA technology, Nvidia Lumenex Engine, NVIDIA Unified Driver Architecture (UDA), Nvidia GigaThread technology, Dynamic Overclocking Technology (D.O.T.) Express, Nvidia PhysX-Ready, MSI Dual CoreCell Technology
  • Max Resolution (external) 2560 x 1600
  • API Supported OpenGL 3.1, DirectX 10.1
  • Digital Video Standard Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
  • HDCP compatible Yes
Expansion / Connectivity
  • Interfaces 1 x DVI-I (dual link) - 29 pin combined DVI, 1 x VGA - 15 pin HD D-Sub (HD-15), 1 x HDMI - 19 pin HDMI Type A
  • Compatible Slots 1 x PCI Express 2.0 x16
go to here for drivers
http://eu.msi.com/index.php?func=searchresult&keywords=N220GT-MD1G&table=download
hope this helps
John
    My VGA has been corrupted. How can I fix it?
    Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust ,
    If supported you can run a LINUX disk like Ubuntu in live / try mode
    If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue ,
    but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault
    If a likely software issue then uninstall and then reinstall the video card
    Consult ASUS or Nvidia support
    The procedure is something like this
    Onboard video support ?
    yes
    uninstall the video card driver and any video vendor configuration applets
    Uninstall video card in device manager if still present.
    Shut down and remove mains power cable
    remove the hardware video card ,
    (using anti static electricity procedures)
    Attach onboard video to display
    Power up and enter and configure BIOS setup if required, ie 1st seek onboard video
    Bootup to Windows
    Install the onboard video device
    using Windows plug&play default driver executed during booting
    Restart
    Confirm working ok
    Update the chipset driver (inf) if applicable,
    restart
    Shutdown
    Reinstall the hardware video card
    Attach to display
    Reconfig BIOS setup if required
    Start to install default driver
    Install video driver / update from card default using a known good driver whose setup file has been previously downloaded
    restart and test
    Hope this helps
    Gigabyte geforce gtx 650 oc 1gig how to overclock it
    Get MSI Afterburner software. Simple and easy to use, but don't over-do0it or you might cook it good. Google MSI Afterburner. It works for all sort of video cards.
    Black Monitor, (NO SIGNAL FOUND)
    Start your computer with monitor attached to the onboard graphics poart,
    go to bios,
    search for graphics setting and change it to PCIE.
    Exit while saving changes connect your cable to graphics card port.
    This will solve ur problem.
    Which motherboard is good for n9500gt-md1g?
    Here is the compatibility details friend
    Microsoft Certifications Compatible with Windows 7
    API Supported DirectX 10 , OpenGL 2.1
    motherboards supporting : Intel core 2 duo, dual core, Intel I5, I3 ,I7
    enjoy the high resolution...good choice
    "be free to ask further doubts friend am here to help u based on computers:-)"
    I lost my driver cd of msi n9500gt md1g oc d2 -graphics card.i want the driver of it.can you help me.
    http://drivers.softpedia.com/get/GRAPHICS-BOARD/MSI/MSI-N9500GT-MD1G-D2-Display-Driver-18206.shtml
    http://www.nodevice.com/driver/N9500GT-MD512_D2/get51415.html
    2answers
    I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
    Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
    Msi on board video
    the cd that came with the board should have the right drivers on it for your onboard graphic card. if not here is the driver:
    http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=558
    Top MSI Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Sean Wright
    Sean Wright
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
