Maytag MAH8700A Front Load Washer Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The washer has stopped mid-cycle with water in the drum and the door locked. 'ND' is flashing on the display. How dod I get the cycle to re-start?
robert
Level 3:
  • Maytag Master 2,548 Answers
  • Posted on Jun 26, 2016
robert
Maytag Master
Level 3:
Answers
2548
Questions
0
Helped
869601
Points
8043
First, try a spin only cycle and see if it drains the water. if it does, the pump and controls are working. next, try a wash cycle on cold/cold and see if that works all thru the cycle. if it does, then it could be as simple as a new thermistor, a very inexpensive part, about $6. good luck and let me know
steve quate
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 25, 2016
steve quate
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1778
Points
I relaxed my pump with a brand new one and the code came back on during next wash. Did I miss something? I blew all lines out.
Richard Roth
Level 3:
Top Expert:
  • Maytag Master 9,472 Answers
  • Posted on Jan 06, 2011
Richard Roth
Maytag Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626601
Points
28464
"ND" refers to a No Drain issue . check for restrictions in the pump assembly, restrictions in the drain hose, loose wire at the pump, or it's a bad pump.
  • 1 more comment
  • steve quate Jun 26, 2016
    Don't know what else to do. I blew out the line from pump to drain. Then the main drain going to septic line in house, replaced pump with brand new pump. Crimped the terminals down for tighter fit on connection, what else could it be? It's got to be electrical now, I'm thinking. Is there a relay or switch controlling pump? Thank you'd I much for any help I'm broke so gotta fix myself
    Richard
    You like your the man on this site. Ohave t workedin1 weeks so I gotta fixthis myself Maytag Neptune # MAH8700AWW, getting ND code, blew out drain from pump to house drain, blew out house drain, R&R with new pump1/2 way I to 30 mint wash cycle Bam "ND" pops up I don't know what else to do, I've tried everything. Is there a control relay or something I need to replace. Thank you so much, any help you can give me
    Sorry meant to say I haven't worked in 11weeks so I gotta fix this myself. Thanks
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
The water starts to come through then just stops and then alarms go off
My maytag epicz will run water and then just stop it lock and later get code f33
2helpful
Washer stops during rinse cycle and beeps at me
Whirlpool 1000 w100 stops after filling with water
Agitator starts wont quit
see the diagram
Washer stops at rinse cycle and give the ul code F1
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
1helpful
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
