I guess you are using it thru a USB, try a differnt USB port if you have more than one USB port on your PC....else
try it on a different PC
or
a longer solution is to get a low level format software like "killdisk".....this is also a DOS based application....install it and use the in Win or thru a boot diks DOS application
revert back
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Note:
