GE 29888GE1 Digital Answering Machine Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to program correct time and date - GE 29888GE1 Digital Answering Machine
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • GE Master 102,366 Answers
  • Posted on Oct 27, 2011
GE Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440282
Points
622693
The instructions are in the third column of the manual.
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
HOW TO SET DATE AND TIME
You need to set the date and time from the default extension "the programming extension" normally extension 20 or 21. You need to enter system programming mode - refer to user manual, then once set, all handsets should display the correct date and time.
Dsc-w150 need photo date stamped
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
2helpful
How to set the date
1. Open the front cover to show the programming buttons:
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting: Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button until the correct hour is displayed. Press Select to set the hour shown. The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select to set the minutes shown. The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select. The Year will blink. Press the Setting button until the desired year is shown. Press Select to set the year shown. The Month will blink. Press Setting until the correct month is shown. Press Select to set the month shown. The Day blinks. Press Setting until the correct day is shown. Press Select to set the day shown
If you need additional instructions the manual can be found here: TC100 Manual
Hope this helps, Myridom
Setting date and time on photo
As long as the current date and time are set correctly, the camera will always store the date with the picture. If you want to print the date with the picture, please refer to the documentation for whatever program you're using for instructions.
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
1helpful
Computer setting of date and time unstable
Could be a flat backup setting battery (aka cmos battery)
workarround
use a program to automatically update the clock like
NetTime available HERE
Need to change date on phone system to reflect correct time
OR, you could go to the programming phone and program it yourself.
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
18helpful
4answers
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
15helpful
4answers
Changing Time
Hey peoples this worked for me :)
On the main phone
- hit the "PROGRAM" key
- then key in **
- it asks for a password key in 1234
- then key "NEXT"
- then key "ENTER" (this is to set the date)
- then key "NEXT" (this is too set the time)
- once the time is correct hit the "ENTER" key at the bottom of the phone.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
