It doesn't matter to the camera what software you have on your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Casio EX-Z120 Lens Stuck
i have also same problem what should i do ???/ plz help ma e-mail is [email protected]
SOURCE: need a usb cable for casio ex-z60
Don't know if ya found your answer yet, here's a site I found.
http://www.bestlaptopbattery.com/b.cfm/Digital-Camera/CASIO/Exilim-EX-Z60/Digital-Camera-Data-Transfer-Cable-.htm
SOURCE: Can't download from Casio EX-Z120 to iPhoto on iBook OS10.4.11
1) Create a new folder on your Desktop or in your Pictures folder. This is where you will copy your photo files.
2)
Click on File, then New Finder window. Size these finder windows so you
can see both of them at the same time. In the second window, go to your
computer, and then to the drive that represents the memory card in your
camera.
3) Drag and drop to copy the files from the camera's
memory card Finder window to the new folder Finder window, dropping the
files into the new folder on your computer's hard drive.
4)
Use command+tab to change back to iPhoto. Cancel from the import
warning window. In iPhoto click on File then Import to Library
5)
In the import dialog tell iPhoto to move the photos (not to import them
in their current location) so that iPhoto puts the photos in the same
place it put your other photos when it imported them directly from the
camera.
If you can't do all of these steps, tell me how far you got, and what happened and we can take it from there.
SOURCE: how to download software to casio EX-Z600 camera?
Here is the link for the manual. It's a pdf file, open the link and save the file to your computer. http://exilim.casio.com/resource/pdf/manuals/EX-Z600.pdf
