If you're looking for better result, just go to a SAMSUNG UNLOCK CODE website for your samsung sgh-b210 unlock code. Just use the IMEI unlock code provided by them. You don't have to worry about data or contact loss. It is 100% safe and accurate.
My Friend,
In My Knowledge .Unlock Your Samsung.Through Imei Unlock code Is More Convineint.You Can Unlock Your Samsung. Call Your Network Provider To Ask Your Samsung SGH-B210 Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy Samsung Imei Unlock Code From Third Party. Many Sites Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
SOURCE: i would like unlock code so my samsung SGH-X530 accepts any sim please
1. remove your simcard
2. type *2767*3855# ALL DATA WILL BE LOST.
If the phone is locked with firmware then the code wont work.
let me know if it works.
SOURCE: SGH-A867 Samsung unlock code. I am trying to
USE ALL * AND # INCLUDED WITH CODE .PLACE DIFFERENT SIM CARD IN PHONE ANY OTHER THAN ORIGINAL DONT WORRY THE CARD WONT BE HARMED READY LETS TRY?ENTER THIS CODE
*7465625*638*00000000*00000000#HIT END KEY ONCE THEN ENTER *2767*2878# WAIT 10 SECONDS PHONE WILL REBOOT NOW ENTER #745625*638*00000000# PHONE SHOULD BE UNLOCKED NOW TRY YOU SIM AND SOMEONE ELSES YOU CAN USE DIFFERENT NETWORKS NOW GOOD LOCK.
SOURCE: samsung SGH-x475 t-mobile unlock code
sure the unlock code goes as follows... *2767*6903557610011172#
after you do that it will seem to shutoff but leave it and it will then open up to working screen... you will have to enter this code each time you turn off the phone but it should work,,, if u have any questions... e-mail me at [email protected]
SOURCE: i need the network unlock code for samsung SGH -E390
To unlock your samsung mobile,follows these steps
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next
a SIM card from a different service provider needs to be pushed half in
- (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter:
#7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock:
#7465625*638*00000000#
The phone is finally unlocked.
