SOURCE: keurig elite b40 cup lights don't flash. Both are
Lift the handle to open the k-cup holder and then close it back up. The coffee mug lights should begin to blink for you.
SOURCE: unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
SOURCE: Does not always brew
I just fixed mine. Remove the reservoir and unplug the unit. Open up the bottom by removing the 5 screws in the base. Find the part of the intake hose directly under the reservoir. Two screws hold it in, so remove them. Pull the black plastic cover back from the clear silicone receiver. There is a black plastic filter inside the silicone. Pull it out. It is probably filled with goop. Use a toothbrush to scrub that stuff out, top and bottom. Replace the black filter, flat side first. Replace the cover and screws, the the screws on the base. This works like magic. I have taken mine apart three times to try to see what was wrong, but nothing worked until this fix.
May still be able to get a replacement or repair for free under warranty.
HOW DO YOU OBTAIN WARRANTY SERVICE?
Keurig® brewers are high-quality appliances and, with proper care, are intended to provide
years of satisfying performance. However, should the need arise for warranty servicing,
simply call Keurig Customer Service at our toll free phone number 1.866.901.BREW (2739).
Please do not return your brewer for servicing without first speaking to Keurig Customer
Service to obtain an Authorization to Return number (ATR). Keurig® brewers returned
without an ATR number will be returned to the sender without servicing
http://m.keurig.com/medias/Keurig-Hot-Cl...
