Your laptop:-"Toshiba Satellite A75-S209" is compatible with the Windows 7 operating system.Thank you for your time and best wishes for your effort.
Because the laptop is made before Windows 7 is made. If you try to look at the drivers website (Click Me). There is only Windows XP and Windows Vista drives that is available not Windows 7. refer to the figure
Hi, this is a known issue in many Laptops which have upgraded to Windows 7 Operating System. I suggest that you check for the Drivers compatible with Windows 7 Operating System by visiting Laptop Manufacturer's Website. By installing all the updated Drivers of Windows 7 the Laptop functions as expected. If the laptop manufacturer doesn't provide Windows 7 Compatible Drivers then you have to downgrade to Windows XP. Please install WIndows XP to get rid of the replace battery message. The issue is not related to Battery.
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
Studio 1537 is one of the classic models from Dell and it definitely compatible with win 7.. This laptop can be used for high end gaming and visual effects.. Its a good one...
The first thing you should do is assure yourself that the ati 3470 is 7 compatible. If it is, either (1) you already have the driver in 7 or (2) ati gave you a driver with the device.<br />
<br />
Check compatability on the package and/or visit this site and check for yourself: <a href="http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx">http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx</a><br />
<br />
Thanks for your interest in FixYa.com
Hi i'm Rain.
Ok first you need to locate you D-Link Driver.
Then you need to check the compatibility.
Most things running Windows 7 are compatible to Windows Vista
Find the D-Link Icons right click and look for compatibilitiy.
Or click properties then look for compatibility.
Click compatiblity and select Run Compatible With: What ever your system was.
If you got it with windows 7 . You may have to try each Compatibility : 2000/XP/Vista . Until you pick the compatible configuration..
I had the same problem when i upgraded.
Sure, because your laptop configuration complete the minimum requirement for windows vista or
If we are unsure of an application compatibility with Windows 7, the following Microsoft link provides searching capability to identify if a specific application / device will work with Windows 7 or not:
