Akai PT5492S 54" Rear Projection Television Logo
Posted on Jul 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO HIGH DEFINITION
I HAVE A 54 Akai Projection TV,.. Model Number is PT5492S. Does this model have high defintion capabilities? .
  • RSCHWERDT Jul 26, 2008
    REAR PROJECTION TV. TIMER LIGHT STAYS ON AND TV WILL DO NOTHING, NOT TURN ON OR ANYTHING??
Anonymous
Level 1:
Problem Solver:
  • Contributor 22 Answers
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
22
Questions
Helped
3980
Points
23
Is it hdtv 1080i yes or no
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
338
Points
A clarification on EDTV vs HDTV - they are not interchangable.
Unfortuanately, there are so many blogs, white paper and uninformed salespeople out there now, it's easy to get confused.
Video Resolution Levels -
480i = 480 x 640 - SDT - 4:3 (Interlaced scan)
480p = 480 x 704 - EDTV - 16:9 (Progressive scan)
720p = 720 x 1280 - HDTV - 16:9 (Progressive scan)
1080i = 1080 x 1920 - HDTV - 16:9 (Interlaced scan)
1080p = 1080 x 1920 - HDTV - 16:9 (Progressive scan)
The HDTV Video 'Standards' originally agreed upon were 16:9 aspect ratio with 720p or 1080p resolution (1080i is the best resolution currently being broadcast. This may change after Feb 2009, when more bandwith is freed up by the d/c of Analog broadcasting).
Enhanced Definition Television [ EDTV ] - 480p (480i backward-compatible) :
EDTV has the same resolution as Standard-Definition Television (SDTV), but with progressive scanning, which creates a smoother overall picture, instead of interlaced scanning.
EDTV has a picture that is superior to that of SDTV, (480i), but not as sharp as high-definition television High-Definition Television (HDTV - 1080i/p).
A EDTV is capable of displaying the 480p (progressive-scan) format at up to 60 fps with either a 16:9 or 4:3 aspect ratio rather than being limited to SDTV’s 480i (interlaced-scan), 30-fps format.
SDTV’s can receive enhanced-definition signals (480i & 480p), which do not have the detail of an HD signal but do improve on the Standard-Definition (SD) picture.
As stated above, EDTV can be in either the 4:3 or 16:9 aspect ratio, for a resolution of either 480 x 640 or 480 x 720 pixels.
HDTV signals can be displayed but because it doesn't have enough resolution to really do the images justice - EDTV's don't provide as much detail as displays with higher native resolutions (1080i/p).
Jaime Hernandez
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Master 2,351 Answers
  • Posted on Jul 10, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782906
Points
6681
  • HDTV capable: Yes (up to EDTV, 480p)
  • Add Your Answer
    My tv wont start up. I had the color wheel replaced 11 months ago at a cost of $285. the tech that did the work says he only warrants his work for 90 days. How much is the color wheel and is it...
    The PT5492S doesnt have a color wheel since that model has three CRTs instaed of the single lamp. Double check the model number and I will assist with the issue.
    2answers
    AKAI PT5492S - Makes a ticking noise,black
    This usually is indicative of the EXTREMELY HIGH VOLTAGE anode connection somewhere between the flyback transformer and one or more of the crt picture tubes or the splitter. Being that this circuit has a running voltage potential of over 30,000 volts if you are not familiar with these YOU CAN BE KILLED messing with it!!! What happens is that there is a breakdown of insulation over time usually from dirt or other environmental contamination. Usually a good cleaning and replacing the HV anode wire that has failed. (hint) it will be the one that the "ticking noise" is coming from. The ticking noise is actually the high voltage arcing to the chassis/ground.
    Be careful!!!!
    Akai tv model PT5492 has real bad orange tint that will not go away, with any adjusting.
    it souds like your blue and green tube are getting weak and will need to be replaced
    unfortunately they are no longer avail I would think about retireing that set
    What is the oem lamp # for an akai model#pt5492s and where is the best place to purchase one?
    Only DLP TVs have a lamp ,projection has 3 tubes red/green/blue. Call Encompass for power supply board, Akai is the same as Samsung.
    1-800-638-3328
    No picture, only sound from my Akai PT5492S
    This set does not have a bulb. It could be a number of things; a high-voltage problem or if the convergence IC's are bad this would prevent the set from comong on.
    PT5492S Akai PTV
    That unit has a couple of various problems that are common. The first, I would check the 2d comb filter for ring cracks. If you see any resoldering them should restore the picture,
    Bill
    AKAI PT5499HD
    hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
    thanks
    2answers
    "NO Picture" 54" AKAI model PT5492S
    I just had that problem. Check the terminal board that is on the left if you open the back of the TV. There is a thing in there with the number aa93-something. If you check under that board there should be some solders that have come loose. I just fixed this problem last night!!
    Top Akai Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Accurate TV Repair...
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
