Question about Dell Dimension E521 PC Desktop
Hi, I have a dell dimension e521 I hook up a old monitor to it and, it work but whei i hook up a new flat screen monitor it said (can not display video
    Scholar:
  • 111 Answers
Are you using the same VGA cable. Try to use the same VGA cable which is there is in Old Monitor
Though it can be issue with the resolution setting also of the Video
For that when you plug in your desktop to old monitor bring the Resolution to the minimum and then Connect it to your New Monitor
Posted on Jan 06, 2011
SOURCE:
My desktop dell dimension E521 won't come on. The power button just blinks green. A new power supply was tried but that did not work. What is it likely to be and is it gonna be worth fixing?
E521 motherboards are pretty reasonable: http://shop.ebay.com/i.html?_from=R40&_trksid=m570.l1313&_nkw=dell+e521+motherboard&_sacat=See-All-Categories so it is worthwhile to fix.
The 570 is a decent system although I am still an Intel guy myself
Aug 12, 2011 | Dell Dimension E521 PC Desktop
My Desktop computer is dead
it means that the monitor is not receiving any signal from the cpu, check the cable that goes from the tower (cpu) to the monitor
Jun 06, 2011 | Dell Dimension 2400 PC Desktop
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
My e521 screen is black & in power saver mode, can not acess any screen or do anything at all.
Narrow it down to a monitor issue (and fix or replace the monitor in particular) or a PC issue (in which case we're also low on info. about the issue.)
Jan 03, 2011 | Dell Dimension E521 PC Desktop
Help! My dell dimension E521 will not boot after
Its seems like your RAM is not working properly, so once you replace the this RAM and check it, you problem should be resolve.
Regards
Ashly
Feb 01, 2010 | Dell Dimension E521 PC Desktop
Number 3 and 4 on front of the PC are flashing and
3 and 4 for that model correspond to a memory issue. There is possibly a chip that has come loose or has gone bad and needs to be replaced.
Dec 11, 2009 | Dell Dimension E521 PC Desktop
I have a Compaq Presario laptop with a broken
Hi:
Just plugging in the monitor to your VGA port on the laptop won't make it display. You have to toggle to the exteral display, or both. Usually you have to hold down your function key, and then hit the external display key. It could be F1 thru F8, depending on your laptop model. Mine is F6. If you toggle thru the modes, your CRT should display . The missing pin is no concern!
Dec 11, 2009 | HP Compaq Presario F761US Notebook
Dimension e521 black screen no video signal
if your num lock key responds, you may have to reseat/change the video card (if you are sure monitor is good). else you need to replace your motherboard.
Getback if you need any clarifications
Jan 09, 2009 | Dell Dimension E521 PC Desktop
DELL PART # DN804 For E521 computer
Hi
Dell Part # DN804 is PCI-e ATI Theater 650 Pro Combo Analog/Digital TV Tuner and it is compatible with Dell Dimension E521.
The ATI Theater 650 Pro PCI-e card is available in two form factors - Low Profile or Full Height. Dimension E521 is compatible with Full Height cards only. It is important that you ensure the you receive a full height card.
Check Installing a PCI Express Card for help installing the hardware. Next install required software/drivers.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1080274
Mike
May 03, 2008 | Dell PART NUMBER CARD NTWK PCI TR IBM 16/4...
Dell Dimension E521 PC Desktop Logo
85 people viewed this question
Clive
Clive
Alun Cox
