Hi, try hitting the reset button as a first step when it comes on. You might have to do a hard reset. Make sure you have either your original firmware or the latest from Archos saved on your desktop. When you do a hard reset if it comes to the Archos screen hold down the volume+ button until the white recovery screen comes on. If you have data you don't want to lose in it you might be able to save it if you try the repair or recovery function but if they don't work you will lose everything if you have to format. You probably will have to format sorry for the bad news but try everything first before formatting.
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
it will come up with white screen again but this time it will start
Update you will see the progress bar moving wait until it is all done
and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
If you chose any of these options already your Os is gone..
try this solution
(104) on it. This might work for other error codes too. These are the steps i
followed * Use thecomputerfor this
process that you always used for this archos Archos should be plugged in to Pc
before starting the process. * Download the firware Upgrade 2.1 * Plug the Archos toPc * When the white option screen comes up pick the
format disk * Wait until all done do not pick any option on
archos after format is done Pc should recognize your archos in 5 seconds * Put the firmware in root section of the archos not in any folder. * Safely remove the usb for Archos from your pc
first and then unplug thecable. * Do not pick any option on the Archos screen * Just turn it off from the power button by
holding it until it turns off * Wait about 5 minutes and plug it back to pc * it will come up with white screen again but this
time it will start Update you will see the progress bar moving, wait until it
is all done, it will shut off. Turn it back on and your archos will be back to normal
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed * Use thecomputerfor this process that you always used for this archos Archos should be plugged in toPc before starting the process. * Download the firware Upgrade 2.1 * Plug the Archos toPc * When the white option screen comes up pick the format disk * Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds * Put the firmware in root section of the archos not in any folder. * Safely remove the usb for Archos from your pc first and then unplug thecable. * Do not pick any option on the Archos screen * Just turn it off from the power button by holding it until it turns off * Wait about 5 minutes and plug it back to pc * it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and your archos will be back to normal
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed * Use thecomputerfor this process that you always used for this archos Archos should be plugged in toPc before starting the process. * Download the firware Upgrade 2.1 * Plug the Archos toPc * When the white option screen comes up, just pick the format disk * Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds * Put the firmware in root section of the archos not in any folder. * Safely remove the usb for Archos from your pc first and then unplug thecable. * Do not pick any option on the Archos screen * Just turn it off from the power button by holding it until it turns off * Wait about 5 minutes and plug it back to pc * it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and your archos will be back to normal
hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
