Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
That was the first thing I tried - thanks
Discovered a covered icon on the desktip that did the trick. Thanks
