Bosch 23 in. SHU33A Built-In Dishwasher Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No Water getting to sprayer, louder humming noise
Sam
Level 3:
  • Bosch Master 3,247 Answers
  • Posted on Jan 06, 2011
Sam
Bosch Master
Level 3:
Answers
3247
Questions
0
Helped
1305030
Points
10378
Looks like the wash motor is failing. I am assuming the water inlet is ok and you have water sitting at the base.
You may have to checkout item 15 in this diagram.
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
2answers
Washer fluid not spraying
Does the motor make a noise like its trying to pump when you press the water button? Best way to check is when the car is off and you turn the key to accessories, then try the water. If you hear a humming noise, your fuse and motor are working and you have a blocked spray unit. Just use a pin to unblock it.
If you dont hear a humming noise, locate the fuse and see if it is faulty. If the fuse is fine, your motor is bad so replace it. Hope this helps
2answers
Have loud noise from engine,gets louder w/more rpms.it is an automatic,60k miles.no exhaust or muffler problem.
Serpentine belt tightener pulley bearing was bad, made a loud noise. I replaced the pulley (jobber part) and the noise level was reduced enough to notice the waterpump was also making a noise ... more revs = louder noise. I am now replacing the water pump. (approx 60k Miles too).
1helpful
Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
2helpful
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
3helpful
Humming noise thru my speakers
You are getting engine noise through your amplifier. To solve this problem you will need to install a filter in-line with the DC path, or install a voltage regulator in-line with the DC path.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
