This works for alarm only. If you have remote start as well, you will need to press the valet button 3 times. The valet button is a small red button that was probably placed somewhere along your lower dashboard under your steering column. It is to put the alarm into "valet" mode when you use it, which is basically to temporarily override the unit. The valet button is used as part of the programing process in addition to being how the valet feature is turned on and off. How to program AutoPage XT remote
The first link is a discussion page where someone asked for the manual. The second link is the manual. Apparently the manual is for a different system the works the same way. From the first link: "The 43LCD does not have an owner's manual. Instead, the manual to which the remote is compatible with is the 'manual' it is associated with, link below. "
The Autopage XT-42LCD is used to operate two systems, the RF-420LCD and RS-622. Since you state that you need to activate a remote start that narrows it down to the RS-622. You can download the manual for this unit at the following link:
This system is recommended for the professional installers only.Any small wrong wiring will damages the full system and it will become useless.And there is no installation guide for this unit.It is kept confidential.
Thank You
FIND THE VALET SWITCH AND PROGRAM MANUAL. REPROGRAM YOUR REMOTES. IF THAT DON'T WORK MAKE SURE YOU HAVE 12 VOLTS AND A GOOD GROUND CONNECTION AT THE XT-59.
How do I reprogram my autopage xt-74 iced remote
