Washing Machines Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a fisher paykel ecosmart washer that will not agitate. It tries to then stops and starts beeping. Do you know what could be causing this?
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Apr 21, 2018
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314680
Points
1478
Its probably the rotary position sensor,it would help if i knes what lights are on at the time
5 Related Answers
Anonymous
  • 288 Answers
  • Posted on Dec 18, 2007
SOURCE: washer will not spin
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Anonymous
  • Posted on Jan 11, 2008
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Anonymous
  • 145 Answers
  • Posted on Dec 18, 2008
SOURCE: ecosmart gw11 fisher paykel
Hello and welcome. Couple things to check first-
Tip the machine back and look underneath at the water pump, if it is wet or appears crusty/corroded, you probably have a shorted pump that took the machine control out along with it. Sometimes you can just replace the pump but on those models the board can become a casualty. Also look at the control itself and check for water in the pan area underneath it. Sometimes the mixing chamber thermistor leaks and it will short out the machine control. Whenever you replace the control, a new seal should be put on the thermistor. (easy and cheap insurance)
You might want to start with a fisher paykel gwl11 service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=17
Anonymous
  • 51 Answers
  • Posted on Jun 14, 2009
SOURCE: Fisher and Paykel EcoSmart GWL15 Machine won't
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Anonymous
  • Posted on Oct 04, 2009
SOURCE: I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
My ecosmart washer doesnt spin, and after about 30 seconds it beeps
Can you tell me what lights are on when it is beeping
so i can work out what fault code it's displaying.
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Fisher Paykel ecosmart starts to drain for a few seconds then stops.
it could be you have somthing caught in your pump and your belt is sliping that will cause the burning smell take of your pump and check this is the first thing to try please let me know
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
5helpful
THE WINGS ON THE AGITATOR ON MY FISHER PAYKEL ECOSMART TOP LOAD WASHER ARE BREAKING OFF. CAN I REPLACE THIS EASILY?
yes loosen the wing nut nd remove nd replace , u can order part from F&P direct 1800650590 ask for spares
1helpful
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Lots of beeps
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
