The montor does not have that resalution
2 years late again are you on a roll?
2560 x 1600 at 60 H
that is what the monitor can do.
Dell™ 3007WFP-HC Flat Panel Monitor
what MAC can do is the problem. here.
NVIDIA 6600 video card
that is not complete model number
but the drivers from Nvidia.com only work here.
if not loaded correctly the PC mac will use
lower resolutions until you learn to load
said drivers.
same answer on PC as Mac
drivers.
NO MAC OS stated, so that is a problem on the G5/
OSX? that?
looks like that card is NOT Supported in the MAC. so you bought the wrong card.
but here is where to ask.... for SURE
https://forums.geforce.com/default/topic...
2 years late.
SOURCE: False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
SOURCE: Dell 2407WFP Monitor losing signal and having colored line artifacts
To your problem number 1:
I would check to see what the refresh rate is on your main monitor. Especially after waking the monitor from sleep, Windows tend to forget the refresh rate settings on secondary monitor and set it to the same as your main monitor. If your main monitor is set at 75hz or something, it could cause the secondary monitor to display the "out of range" message. When you reset the "extend my desktop to this monitor" setting, it probably resets the refresh rate to 60hz again.
This can sometime be remedied by checking to see if the monitor drivers are installed correctly. A lot of times the video card driver also gets in the way. I've had a lot of experiences with ATI drivers behaving very sporadically with multi-monitor setups, where they will consistently change to "plug-n-play monitor" and thus reverting any custom setting I have.
As to your problem #2:
I've had a fair bit of experience with this as well. The fact that the line shows the same way regardless of the monitor's own tilting orientation, means the error is probably coming from the video card signal rather than the LCD panel itself. This usually is a foresight of a nVidia card that's about to break.
I've went through many, many nVidia video cards over the years. They all inevitably break over time, probably because nVidia relies strictly on third party vendors... and to stay price competitive the third party vendors cut corners wherever they can. I always get the same horizontal line error over time as you described here.
The only way to know for sure, is to get a replacement video card, borrow one from a friend if you can, and see if the same problem still comes up. It's very possible for this to show up on only one of your two monitors. Try switching the monitor output as well, to see if the line now shows up on the other monitor instead.
SOURCE: can not select dvi input 2.
Witam
Mam wprowadzon?? blokad?? wy??wietlana jest k??ódeczka gdy przycisn?? jakikolwiek przycisk.Jak to zlikwidowa??.Potrzebny schemat zasilacza oraz inwertera.
Dzi??kuj?? za zainteresowanie
Pozdrawiam
I greet
I have introduced blockade k??ódeczka be displayed when I will press any button.How to do away this.Necessary patern of feeder as well as inverter.
I thank for interest
I greet
