SOURCE: Change Windows XP language from Chinese to English
If the menus are all in Chinese then you will need to install an Enlgish version of Windows XP.
Go to http://www.asus.com then select "Services" and click "Support". In the next window, click "Download". In the next window select "Product, Series & Models" in the selector boxes and click "Search". In the next window, select your Operating System. In the next window, click the Plus(+) sign next to manuals and scroll to the English Manual. When you read it, go to "System Recovery" if the left column and click. in the right column, You will see you need a USB external DVD drive. Reading further will tell you how to install the OS. If the system will allow you to change the language, it will be when you install a new OS.
just move out to a clear area. u may be at a place where there is no signal. Or for a coution restart your device in an open space. U may try reinserting ur SIM for that purpose
SOURCE: I can not connect my ASUS P320 MTNL GPRS What are
In this tutorial we will be using the i-Mate or ALL O2 Xda with an MTNL SIM installed.
Configure Device for WAP Access
1 Tap Start
2 Tap Settings
3 Tap Connections tab
4.Tap connections icon
Now
1 Under My ISP, select Add a new modem connection
2 Enter a name for your connection: MTNL_GPRS
3 From the Select a modem drop down choose Cellular Line (GPRS)
4 Tap Next
5 In the text box labelled (Access point name) type in
for post-paid : gprsmtnlmum
for pre-paid : gprsppsmum
for post-paid : gprsmtnldel for delhi
for pre-paid : gprsppsdel for delhi
6 Tap Next
7 Enter User name mtnl , Password mtnl123, Domain leave it as blank
8 Tap Finish
9 Do not change any thing else in the setting
10 Tap OK twice.
Now you Tap to manage existing connexions under MY ISP ( that you have created above)i.e. MTNL_GPRS.
Delete
Connect
Tap & hold the stylus so that you ‘ll be seeing a pop-up like below
Now click on connect and wait for some time. Once you See the G symbol (or two arrows) on the top most bar ,you are connected to MTNL GPRS network.
Now go to internet explorer from Start and enter http://wap.mumbai.mtnl.net.in to visit MTNL Mumbai’s wap site.
