Zebra Eltron P310 Thermal Printer Logo
Karen Jones Posted on Apr 14, 2017
I purchased a used Zebra Eltron P310C a few months ago - didn't have time to play with it, but need it up and running now. It's running on Win XP. I've installed the Zebra i Series Card driver & it selected the Eltron Parallel Port. I can see the printer, when I try to print a card, the printer hums, the print job goes to the printer, then disappears without printing the card. I've also installed the Eltron P310 Card Printer and that's on Com1 Serial Port. That one shows as a print job, but disappears without printing. This printer only came with a serial cable. There are no USB ports. Suggestions?
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Dec 07, 2007
SOURCE: Zebra LP2844 on com1 long time before starts printing
you need to increase the baud rate of the serial port on the printer and pc, the default baud rate of the serial port is 9600kbp which is heaps slower then the LPT port which can rate atleast 100 times faster.
the reason why it is taking 45sec before printing is because the pc is sending a lot of graphics data to the printer, this can be cause by two main things
1) you could be printing a lot of logos or graphics .
or
2) you are printing using a nonhardware font so the driver has to convert all of the text into graphics. you can fix this by selecting a hardware font (has a printer logo next to it's name in word). also outputting EPL (the printers native command language) would be extreamly quick.
you could also download ZebraDesigner which includes drivers.
i would also recommend not updating the firmware as it can do more harm then good, and if you make a mistake you kill the printer and it voids the warranty
best of luck
Anonymous
  • 45 Answers
  • Posted on Sep 20, 2008
SOURCE: Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Anonymous
  • 3 Answers
  • Posted on Feb 22, 2009
SOURCE: My Zebra Eltron P310 is not working
send to cplus greer SC
Selvol
James Williams
  • 115 Answers
  • Posted on May 28, 2009
SOURCE: feedig problem
Make sure your image is only 1 page.
Possibly the printer is printing the second page blank.
I know you are most likely printing a single card.
But some times LARGE fonts or LARGE images will print as 2 Pages.
Check it out.
Let me know.
Regards
Jim H
  • 62 Answers
  • Posted on Aug 02, 2009
SOURCE: Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Eltron P310C
It happened to me several times and I bought cheap USB Adaptors... Didn't work, but when i bought a better brand, the problem was solved. Normally the cheap adaptors have really bad drivers
1helpful
Where can I get an XP printer driver for Zebra Eltron P310C. Cannot find on Zebra site
Choose model P310F on the drop down located on the downloads page. That driver supports the P310
Increase Speed on Zebra 105SL
In the driver there are settings for print speed, you will aslo need to access the menu on the printer and set the speed
3answers
Looking for 64 bit driver for an Eltron P420
Hello, Jim.
There is no Vista or Windows 7 driver on the Zebra website for your printer. There is only a driver for Windows XP through Windows 98.
Here's the link:
http://www.zebra.com/id/card/na/en/index/drivers_downloads_main/drivers/results.html
Apparently, Zebra didn't create more current drivers.
DO I need the software for the zebra eltron lp2443 printer pluse the driver
The only software you need for the LP2443 is the driver from http://www.seagullscientific.com/aspx/thermal_printer_list.aspx#Zebra
Install this driver, then you can use any windows application that uses win drivers.
Or you can download Zebra designer software to design labels from
http://www.zebra.com/id/zebra/na/en/index/products/software/label_design_software/zebradesignerpro/zebradesigner.html
Feedig problem
Check it out.
Let me know.
Regards
4helpful
2answers
I need driver for win xp of TLP 2742
Go to this link, scroll down to Zebra and click on Zebra to download:
http://www.seagullscientific.com/aspx/thermal_95.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
Zebra print jus blue color
The "i" is the newer series. You will run into problem trying to install the P310C with the P310i drivers. More so if you are running Windows Vista. In that case don't even try.
If your computer has excepted the drivers that you have. Go into the Printer Properties; General Tab; Printer prefs; Advanced button in the bottom right corner ;next, and change the Ribbon type. K is for Black 1 color ribbon.
Try YMCKO for Full COlor. If the ribbon is also YMCKO.
Yellow, Magenta, Cyan, Black, Over lay...
10helpful
5answers
Eltron p310 + Vista driver
i cant find drives forwindows vista....
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
