Yes there is a thermal cutoff that will shut the motor off for a period of time to protect it from getting to hot. If this is what happened after 20-30 mins. the motor should come back on and run again. If it does I would try to clean motor as best I could using a soft brush, vacumn, and blow out with air if possible. Clean fan of f as best you can to help motor run cooler.Hope this helps.Thank you
