The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
One thing I have found is that the used coffee builds up inside the machine and the head can not move. Open the machine's top so you can see the iner workings, you will see the main head and below that a well, this wel should be empty, on mine it was full of old compated coffee, use a chopstick or fondue fork and get all the old stuff out... after that no problems with error message. Still got a leak..... anyone ?
ERROR CODE 06 and/or CODE 07 on the XP7245 model is requesting you to remove the water filter. I had this problem and I called Customer service for the answer. Once you have removed the filter they indicated to allow the unit to go thru set up mode again and then put the filter back in once the machine no longer has an error code.
I didn't actually try it b/c I took my maching back to the store I bought it from only 2 weeks after buying it to get a new one.
I just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
I have a service book available. There is also a very good video on youtube about 22mins long - enter xp7240 in the search bar. If you want a copy of the manual email me at richardsbooth@gmail
I have the exact same problem. I get error no.6 and also error no.1. Anybody know what it means?
Yep me too error no 6
anyone got any ideas?
I tried to do what you said...but the error is stil there...I maked a cofee and when I tried to make the 2nd cofee on the lcd appeared error 6...another solution?
Mine also when its in the restarting procedure its stopping and giving me the error code 06. But i don't have a filter and i am not using one. i think that its not a must to use a filter or its is? I think its something like a problem withe water or the water pump because its grinding its taking the coffee buts the water is not coming to make the coffee. i opened it and i saw how things are happening inside i cleaned everything then again its not working its grinding the coffee its taking inside but the water is not coming.
I have the same problem with my Krup xp7240 at one year and two month old. I had this problem when it's one year old, then I sent it to its official supplier for repair. After two months of using later on, I got the same problem again. This really got me mad. I figure I'd never buy Krup product any more.
