A
Anonymous Posted on Jan 05, 2011
Xerox workcentre 518 gives U6 error whats the issue?
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4253
Points
18
Press 0 button when U6 displayed; If it is U6-0, check control panel connection for proper contact; if U6-1, check paper tray pcb connection to mother pcb.... The paper tray pcb is located at rear side. open back cover and reconnect it.
Xerox Workcentre 6515 giving error code 61-354. 62-280 and 63-386.
Swapping out boards on guesses is expensive.
https://www.support.xerox.com/en-us/article/en/1470317
Looks like your second code should be 62-**3**80?
https://forum.support.xerox.com/t5/Hardware/Workcentre-6515-Device-Fault-062-380/td-p/214038
https://www.support.xerox.com/en-us/article/en/2056725
Xerox online help is not particularly helpful! Google is often a better solution, but in your case, you need a service call. One of those new boards may be faulty.
https://www.google.com/search?q=Xerox+Workcentre+6515+giving+error+code+63-386
Erreur du copieur xerox workcentre pro 423e code U6-3
This error means that there is a Memory Error, and is caused by wrongly grounding the machine. If the problem is not grounding, you'll need to get some parts replacements, and you should book a in site thecnical visit.
Xerox Workcentre 518 U9 Error Code What is the issue??
high voltage power supply gone. u have to change and it costs fortune
2helpful
2answers
What can i download the xerox workcentre 3119 laser printer driver for window 7
Xerox Workcentre 3119 Windows 7 Drivers
Please visit the above link and download the drivers and Installation guide.
Hope it helps! Good Luck!
CreativeTECH
3helpful
2answers
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Error code U6-3
Hello, Assuming this error is persistent and a simple reboot will not clear it. This error means that there is an Memory Error. This might be caused by an improper grounding (earthing) of the machine.
To fix this error, in case the problem is not grounding, parts need to be replaced. So I would advise you to book a visit.
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
1helpful
Xerox work center c118
CRUM ASIC Failure
U6-6000 CRUM ASIC Failure RAP
The CRUM Control ASIC failed.
Initial Actions
Power OFF/ON
Procedure
Check the connection of each MCU PWB connector. The connectors are connected
correctly.
Connect the connectors.
Turn on the power again. U6-6 reoccurs.
End
Replace the MCU PWB (PL 9.1).
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
