I experienced a similar problem with my 52" Sharp Aquos TV. I called and spoke with Sharp service dept. and they walked me thru the process of resetting the TV to it's original "default" values. It worked great once I completed the steps while on the phone with them.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Nah i didnt get into any trouble,, feel free to use us anytime!!! I'm happy the scanner worked if you need any more help you know how to find us..Next time that happens with the scanner try unplugging it restart the system and then plug it back in.. :)
i don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Did you remove the previous driver/software from the other scanner? I suppose you have already tried uninstall/reinstall driver/software, Likely you should have the updated firmware if this is a current scanner. Also, you may want to try importing the scanner source from a different imaging program to see if it has to do with the manufacture software.
