You need to reset your i-mate Jam, for doing so please follow these instruction
i-Mate JAM soft reset
Resetting Your Pocket PC Phone
You can perform a soft reset or a full reset. During a soft reset, the device is restarted and only some data in opened programs may be lost. However, a full reset turns the battery off, returns the device to its original factory settings, and deletes all programs, files, contacts and other information you have saved to the device. Therefore, it is extremely important to back up data to a storage card or your computer on a regular basis in the event that a full reset has to be performed.
To perform a soft reset
If your Pocket PC Phone responds slowly, stops responding, or freezes, you can soft reset it. A soft reset causes the Pocket PC Phone to restart and re-adjust memory allocation. Unsaved data in any opened applications may be lost. Use the stylus to press and hold the Reset button, as shown on the next page.
i-Mate JAM hard reset
To perform a full reset
A full device reset clears memory, deletes all data and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain, erasing all data that you have created and programs you have installed. Press and hold the power button, and then use the stylus to press the soft reset button at the same time. Be sure you have backed up all your data in a SD card or on your PC before performing a full reset.
If you require more assistance, feel free to reply to this post
Regards-BA
what is the excat problem
