Dear Expert
I have a HTC touch and its not able to Sync to my lotus notes calendar via Easy Sync Pro. It gives the error message " Cannot connect to device. Verify that Active Sync is running " even while Active Sync is perfectly connected and running
I had exactly the same problem. I changed location from Easysync on my HTC P3300 from memorycard to internal memory. It worked!!
Using easysync 4.26
Lotus Notes 8.0.2
Active Sync 4.5
In case of Omnia I found a solution.I deleted Easysync pro from my PDA then I reinstalled onto device(main memory) instead of storage card.
Hi!
When i bought HTC P3300, i downloaded trail version of Commontime mNotes to sync Lotus Notes and WM. It installed a certificate on my mobile. When i tried to use Lotus EasySync, it gave error ActiveSyn not running. Later i removed the mNotes certificated from my mobile and restarted LotusNotes EasySync. It worked perfectly fine.
Thx
Using HTC Touch Diamond, and getting exactly same problem.
- ActiveSync 4.5.0
- EasySync 2.4.6
- Lotus Notes 7
Is there anything to do ?
got the same here...
htc touch diamond
active sync 4.5.0 (build 5096), mobile connected and synced
notes 8.0.1
ibm easysync 4.2.6
htc touch diamond
notes 8.0.1
ibm easysync 4.2.6
I have an MDA conpact 4, ActiveSync 4.5.0, Notes 7 and EasySyncPro 4.2.6 and Windows Mobile 6.1. The syncronization is not possible.
I use HTC Diamond, and when I try to sync my lotus notes calendar, it shows the same error message. My easysync version is 4.2.5.
Active Sync 4.5 is running smoothly with the HTC P3300 but easysync with Lotus Notes is not working. It says that Active Sync is not running.....
Same thing with my touch pro
I am running easync and active sync is running but the easync says it is not. I am using a Samsung Omnia (WM 6) phone
I have the same problem as the previous person. Any assistance will be greatly appreciated.
I have the same problem with my HTC Touch HD. I am running Easy Sync Pro 4.26 and Active Sync 4.5 and get the message "Unable to connect, verify Active Sync is running" when it is. I have had no luck contacting IBM (they say it is not their problem), HTC support in Australia (responsive but couldn't help) and HTC support in Europe (useless). I did a complete reset of my phone and reinstalled all software, but nothing works. Have tried all .exe's suggested in this and other forums, but no luck. Help.
same
