No this is not normal. There is a temperature sensor commonly called a klixon that is strapped to the evaporator coil or a plate mounted to the evaporator coil that should cut the heater power if the coil gets warm enough. The defrost timer could be faulty - running slow and defrost may be a bit longer than usual but the temerature sensor should cut the heater off way before the unit gets that warm. I would get another technician as this is a pretty simple problem to diagnose and repair.
