You might have clog in water lines.
If shower is only place where low pressure exists, then clog is probably at shower valve.
Disassemble valve and see if clog will flush out.
From there, you have to keep moving back along cold water line looking for pipe filled with sediment or elbow that has obstruction.
If pressure problem is bad at every cold tap, but doesn't affect Hot water, then clog is inside Cold line somewhere after water heater connects to cold line.
Buy a pressure gauge that connects to water hose.
Buy adapter that also fits pipe thread.
For example Brady BTG 100.
Test outdoor spigot for baseline pressure.
Open cold tap inside house and see how much pressure drops.
Close cold line and open hot tap and see how much pressure drops.
Next, move pressure gauge along cold water line.
Take apart pipes and inspect for obstruction at elbow or pipes filled with sediment.
Look for any place galvanized pipe connects to copper pipe, since this will be likely place for obstruction because of bi-metal corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pipes.
