Bushnell Trail Scout 11-9830 Digital Camera Logo
A
Anonymous Posted on Jan 04, 2011
My camera displays "No SD card" when I do have a
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Jan 11, 2011
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801525
Points
33142
Hello beach.... remove the sd card and check the perimeter of the card to find the locking mechanism. If the card is in the lock position, move it to unlock. Then reinsert the card, turn on the camera and go into the menu. Find format. Format the SD card and then it should be good. Joe
Thanks for choosing Fixya!
Camera does not recognize any sd card
See if camera electronics can be reset. Contact the manufacturer for this procedure. If nothing can be done to restore camera to factory defaults then the electronics are fubar. May not be cost effective to repair.
2helpful
When i insert the memory card in my Kodak c143 east share then i displayed that " memory card is protected (reset switch on memory card)".
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I am having nikon coolpix L18 camera, it is working with internal memory card. When i inserted external memory card, it display "this card can not be used". I checked ext memory card in another...
Your camera supports SD HC, multimediacard and SD memory cards, is that card of a different type? you will get this problem if the card is of too large capacity too, your camera ,might have an upper limit for supported memory capacities.
My goPro hero HD is stuck at "tel" mode, after i hooked it up to a TV. I have tried some forum-solutions with no luck what so ever! When I turn it on it shows the normal "film" menu,...
Find a solution, you can have a try:
1. SD Card out
2. Battery out wait 10 seconds
3. Battery in wait 1 minute (this extra time was the key to getting this sequence to work for me)
4. Power up take a photo, power down (you have about a three second window before it goes into Tel mode)
5. Wait 1 min
6. Power up (NB still no SD card)
At this point camera appears to be working stays in normal mode with --- displayed because no SD card is inserted.
Also interestingly plugging a video output cable into HDTV output socket makes camera go to Tel mode AND when you unplug it camera goes back to normal.
However plugging the SD card sends camera into Tel mode permanently. On the plus side this 1-6 sequence was repeatable and worked every time.
From this point I tried many combination's of video cables, SD cards, formatted, erased waiting....then came the USB cable!
7. Connect USB cable to computer (NB still no SD card installed)
8. Insert SD (Computer should detect card and any photos taken should be viewable)
9. "Eject" Camera from Computer USB
10. Disconnect camera from USB (should power down by itself)
11. Power up Camera, Woohoo! it works again!
BTW, if you don't know how to connect GoPro to TV, you guys can check the following guide for help.
Guide: How to Connect GoPro to TV
1helpful
My Lumix DMC ZS7 reads "insert sd card again" when I have a full sd card inserted. The sd card is "verbatim sdhc 4gb" any idea? Thanks in advance
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
This is a new purchase, never been used. I inserted the card, installed the batteries and then pressed the putton to turn it on but the display on the screen says "Memory Full! Please Insert an SD...
You didn't specify the make and model of your camera, but from what you do say I suspect it uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible. Try using an SD card 2GB or smaller.
Jan 03, 2011 • Cameras
CX7525. Inserted new 4gb sd card. Camera says it needs to be formatted. When I click on the "OK" button to format, it says "card needs to be formatted" again and again. Will not format...
There are no 4GB SD cards. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
2answers
Top Bushnell Cameras Experts
ZJ Limited
ZJ Limited
john h
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
